Black and Decker WP900 Exterior Casing Replacement
  1. Black and Decker WP900 Exterior Casing Replacement, Exterior Casing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the plastic tool, detach the handle tab as shown.
    • Make sure the device is unplugged.
  2. Black and Decker WP900 Exterior Casing Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the Phillips #1 screwdriver, unscrew all of the screws. There should be 8-30mm screws to remove.
    • Be sure to keep track of where each screw was placed in the device for later reassembly.
  3. Black and Decker WP900 Exterior Casing Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Black and Decker WP900 Exterior Casing Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Black and Decker WP900 Exterior Casing Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the back panel of the external casing, leaving all internal components resting in the front panel.
    • Remove the black handle from the main external casing.
  4. Black and Decker WP900 Exterior Casing Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the Phillips #1 screwdriver, remove the two 22mm screws.
    • The metal bracket will detach with the two screws.
    • Using the Flathead 3/32" screwdriver, remove two 22mm screws.
  5. Black and Decker WP900 Exterior Casing Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Black and Decker WP900 Exterior Casing Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pull the power cord out from the control module.
    • Remember, when reassembling the device, the black wire should be on the top.
  6. Black and Decker WP900 Exterior Casing Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Firmly grasping the motor dislodge the internal components from the frontal external casing.
    • Once the motor has been removed, the external casing can now be replaced.
David Hutchings
crwdns2935283:003/28/16crwdne2935283:0
Hello, this is Adam Kinnett from Group 7. You have done an excellent job on your photos as well as the descriptions and formatting.
**One of your Wiki pages on the search says "Back and Decker".
Adam Kinnett - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 1,076
