Black and Decker TR1278B Top Cover Replacement
  1. Black and Decker TR1278B Top Cover Replacement, Top Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the toaster before disassembly.
    • Remove the carriage lever by pulling it away from the toaster.
  2. Black and Decker TR1278B Top Cover Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Toaster will be turned upside down. Clear crumb tray or work over a paper towel.
    • Turn the toaster upside down.
    • Unscrew all four 4mm screws on the bottom using a Phillip's head #2 (PH2) screwdriver.
    • Or a slightly different model has six screws that require an allen wrench (hex key). Ones that have a ball end will not work. I had to use one that had more of a Star of David, pointy pattern to it.
  3. Black and Decker TR1278B Top Cover Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Detach the bottom from the front cover using the plastic opening tool.
  4. Black and Decker TR1278B Top Cover Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the toaster right side up.
    • Support the bottom. The ribbon cable that connects the toaster to the front cover can be damaged.
    • Lift the front cover.
    • Lift carefully. Again the ribbon cable can be damaged.
  5. Black and Decker TR1278B Top Cover Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Detach the bundled cable connector from the toaster by carefully pulling it away from the circuit board.
Dominic Gamonez
crwdns2935283:002/15/17crwdne2935283:0
257 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 8-1, Eyestone Spring 2017 crwdns2935289:0USF Tampa, Team 8-1, Eyestone Spring 2017crwdne2935289:0
USFT-EYESTONE-S17S8G1
crwdns2936753:030crwdne2936753:0 56
crwdns2942667:0crwdne2942667:0 7,539
