This is a replacement guide for the bread grabber springs on the Black and Decker TR1278B.
Remove the carriage lever by pulling it away from the toaster.
Turn the toaster upside down.
Unscrew all four 4mm screws on the bottom using a Phillip's head #2 (PH2) screwdriver.
Or a slightly different model has six screws that require an allen wrench (hex key). Ones that have a ball end will not work. I had to use one that had more of a Star of David, pointy pattern to it.
Detach the bottom from the front cover using the plastic opening tool.
Turn the toaster right side up.
Lift the front cover.
Detach the bundled cable connector from the toaster by carefully pulling it away from the circuit board.
Press down on the toaster lever to gain access to the grabber spring located behind the large metal plate.
Use metal spudger to loosen clamps on spring.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use needle nose tweezers to pull the spring off of its hook.
Repeat this step for the opposite side.
Remove the old spring from the toaster unit to insert the new one.
