Black and Decker Pivot Plus PD600 LED light Replacement
  1. Black and Decker Pivot Plus PD600 LED light Replacement, Drill: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Black and Decker Pivot Plus PD600 LED light Replacement, Drill: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Black and Decker Pivot Plus PD600 LED light Replacement, Drill: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the nine 15mm Philips #1 screws
    • Remove the two 12.5mm Philips #1 screws
    • Remove the two 10mm Philips #1 screws
  2. Black and Decker Pivot Plus PD600 LED light Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift one side of the drill casing off of the drill. Note that the drill casing consists of two pieces on either side of the drill.
  3. Black and Decker Pivot Plus PD600 LED light Replacement, LED light: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • In order to replace the small LED light look below the motor at the front of the drill to find a black plastic piece with two very skinny wires emanating from it.
    • The black plastic piece is the housing. The light is placed inside this black plastic housing.
  4. Black and Decker Pivot Plus PD600 LED light Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the black plastic piece up out of the slot in the drill body that it fits into.
  5. Black and Decker Pivot Plus PD600 LED light Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The light itself can be easily removed from the black plastic piece by simply pulling it out.
    • One of the metal “legs” on the LED is longer than the other and it must be placed in the black plastic housing in the same manner it was removed or it will not work.
  6. Black and Decker Pivot Plus PD600 LED light Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Take your new LED and slide it back into the plastic housing in the same orientation as the old LED.
justin boyd
crwdns2935283:005/13/13crwdne2935283:0
131 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 4-15, Maness Spring 2013 crwdns2935289:0Cal Poly, Team 4-15, Maness Spring 2013crwdne2935289:0
CPSU-MANESS-S13S4G15
crwdns2942667:0crwdne2942667:0 926
