Once you have removed the exterior casing, this guide will show you how to remove and replace the lithium-ion battery in your LI4000.
Remove the stickers found on the bottom and sides of the LI4000, using a spudger.
Remove all six of the 12-mm long case screws with a Philips #1 Screwdriver. These screws can be found on the side of the LI4000 with the "Warning" sticker.
Remove the two screws that are 4-mm Hexagonal #2.5. These are very small case screws that can be found underneath the two stickers from Step 1.
Pry on the seam as shown with a Spudger, in order to get the top casing loose.
Pull the two sides apart while making sure the side that you are removing is the one with all of the case screw holes.
Locate the battery. The cardboard covered cylinder is the rechargeable battery.
Detach the contact by pulling the contact away from the battery.
Gently lift the end of the battery out of the plastic casing
Locate the other contact on the rear side of the battery.
To install a new battery, repeat the steps in reverse order with a new battery.
crwdns2935229:017crwdne2935229:0
crwdns2947412:05crwdne2947412:0
Anyone know what type of battery this is so I can replace it?
Thanks
Brian
If you peel off the paper of the battery, you will find out that it is a 18650 Lithium battery. Mine has US18650VT T11250 label. It seems from SONY.
When looking for a replacement battery, see if you can find one with solder tabs opposite to each other. The internal plastic housing of the battery is made exactly for two tabs opposing each other; I had to cut the plastic here and there to make my battery (with both tabs at the same side) fit.
New one is cheaper than a new battery
new battery costs 10$, its a 18650 or LI4000
