Use this guide to remove or replace the circuit board in your Black and Decker LI2000.
Remove the following five screws
Three 20 mm Phillips #1 screws
One 10 mm #000 Phillips screw
One 13 mm Phillips 31 screw
Remove the black sticker with recycling information.
Use your fingers or a plastic opening tool to pry the casing apart.
Remove the plastic slider by picking it up off the screwdriver.
Remove the four 15mm Phillips #1 screws.
Use a plastic opening tool to pry the casing apart.
Using pliers or your fingers, remove the leads off of the battery.
Refer to the Soldering Technique Guide to remove the wires on the circuit board that connect the charging adapter by applying heat from iron to existing solder on the board.
Refer to the Soldering Technique Guide to remove the wires from the circuit board that connect to the battery by heating the existing solder on the leads.
