Black and Decker LI2000 Battery Replacement
  1. Black and Decker LI2000 Battery Replacement, Orange Casing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Black and Decker LI2000 Battery Replacement, Orange Casing: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Black and Decker LI2000 Battery Replacement, Orange Casing: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the following five screws
    • Three 20 mm Phillips #1 screws
    • One 10 mm #000 Phillips screw
    • One 13 mm Phillips 31 screw
    • When you remove the 13 mm screw, the spring may pop out of the screwdriver. Point the backside of the screwdriver away from your face and others.
  2. Black and Decker LI2000 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the black sticker with recycling information.
  3. Black and Decker LI2000 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your fingers or a plastic opening tool to pry the casing apart.
  4. Black and Decker LI2000 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the plastic slider by picking it up off the screwdriver.
    • You may consider leaving half of the casing on the screwdriver to make handling the screwdriver easier.
    You should also leave the switching slider on the motor as it is DIFFICULT to reinstall the switch assembly.
    Bob - crwdns2934203:0crwdne2934203:0
  5. Black and Decker LI2000 Battery Replacement, Handle: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Black and Decker LI2000 Battery Replacement, Handle: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 15mm Phillips #1 screws.
  6. Black and Decker LI2000 Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Black and Decker LI2000 Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a plastic opening tool to pry the casing apart.
  7. Black and Decker LI2000 Battery Replacement, Battery: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Black and Decker LI2000 Battery Replacement, Battery: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using pliers or your fingers, remove the leads off of the battery.
    where did you get the new battery?
    jack isme - crwdns2934203:0crwdne2934203:0
    YA, don’t find on e-bay or on B&D site. Need PN at least.
    Tom
    Thomas Patridge - crwdns2934203:0crwdne2934203:0
    This is what I got from eBay: https://www.ebay.com/itm/4PCS-18650-2600...
    You have to fudge a bit as the tabs fit the connectors, but are not exactly oriented the same as the original battery.
    Jeff McDermaid - crwdns2934203:0crwdne2934203:0
    Google; Black+and+Decker+LI2000+Battery+Replacement
Katherine Simmons
crwdns2935283:002/08/16crwdne2935283:0
753 crwdns2915208:0crwdne2915208:0
IUPUI, Team 1-3, Baechle Spring 2016 crwdns2935289:0IUPUI, Team 1-3, Baechle Spring 2016crwdne2935289:0
IUPUI-BAECHLE-S16S1G3
It would be great is you could discuss the 3.6v cell - Lithium Type -- Size? Is it an 18650?
William Tzouris - crwdns2934203:0crwdne2934203:0
OK, so where can we get the battery!?
Mike Young - crwdns2934203:0crwdne2934203:0
Check eBay for the 18650 with solder tabs already attached. I purchased a 4 pack of the batteries and used 1 for a LI3100. I needed a Dremel tool to remove some of the internal plastic battery supports to accommodate this battery. If the solder tabs had been oriented 180 degrees to each other, it would have been a drop in fit. Screwdriver works great now!
crwdns2936753:07crwdne2936753:0 19
crwdns2936753:030crwdne2936753:0 62
crwdns2942667:0crwdne2942667:0 10,073
