Use this guide to remove or replace the battery in your Black and Decker LI2000.
Remove the following five screws
Three 20 mm Phillips #1 screws
One 10 mm #000 Phillips screw
One 13 mm Phillips 31 screw
Remove the black sticker with recycling information.
Use your fingers or a plastic opening tool to pry the casing apart.
Remove the plastic slider by picking it up off the screwdriver.
You should also leave the switching slider on the motor as it is DIFFICULT to reinstall the switch assembly.
Remove the four 15mm Phillips #1 screws.
Use a plastic opening tool to pry the casing apart.
Using pliers or your fingers, remove the leads off of the battery.
where did you get the new battery?
YA, don’t find on e-bay or on B&D site. Need PN at least.
Tom
This is what I got from eBay: https://www.ebay.com/itm/4PCS-18650-2600...
You have to fudge a bit as the tabs fit the connectors, but are not exactly oriented the same as the original battery.
Google; Black+and+Decker+LI2000+Battery+Replacement
It would be great is you could discuss the 3.6v cell - Lithium Type -- Size? Is it an 18650?
OK, so where can we get the battery!?
Check eBay for the 18650 with solder tabs already attached. I purchased a 4 pack of the batteries and used 1 for a LI3100. I needed a Dremel tool to remove some of the internal plastic battery supports to accommodate this battery. If the solder tabs had been oriented 180 degrees to each other, it would have been a drop in fit. Screwdriver works great now!
