Black and Decker LDX172C Trigger Switch Replacement
  1. Black and Decker LDX172C Trigger Switch Replacement, Trigger Switch: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before beginning, make sure the motor direction switch is in the neutral position.
    • Place the drill on the work surface with the chuck facing downward. Locate and remove the two #2 X 10mm Phillips screws located right of the motor.
  2. Black and Decker LDX172C Trigger Switch Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Rotate the drill to it's left side - the chuck should be facing to the right. Locate and remove the eight #2 X 5mm Phillips fasteners from the body of the drill.
  3. Black and Decker LDX172C Trigger Switch Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove the right half of the body from the drill.
    • The trigger mechanism is spring loaded and may eject from the drill when the body is removed.
  4. Black and Decker LDX172C Trigger Switch Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Black and Decker LDX172C Trigger Switch Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Black and Decker LDX172C Trigger Switch Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove trigger from drill by pulling the mechanism directly up off the holding pins.
    • The leads from the switch are removed by using a heating the solder until they come free.
    • Re-solder the leads to the new switch.
    • Repeat directions in reverse to reassemble.
jakebontragersinger
crwdns2935283:002/13/16crwdne2935283:0
173 crwdns2915208:0crwdne2915208:0
IUPUI, Team 3-3, Wilson Spring 2016 crwdns2935289:0IUPUI, Team 3-3, Wilson Spring 2016crwdne2935289:0
IUPUI-WILSON-S16S3G3
crwdns2936753:030crwdne2936753:0 39
crwdns2942667:0crwdne2942667:0 3,751
