Black and Decker LDX 120C Chuck Replacement
  1. Black and Decker LDX 120C Chuck Replacement, Outer Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • For this guide we will need to use a 1.0 mm phillips #1 screw.
    • There are a total of thirteen screws that need to be removed in order to open the drill and access the interior components.
  2. Black and Decker LDX 120C Chuck Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four screws on the back top side of the drill.
  3. Black and Decker LDX 120C Chuck Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four screws that connect the chuck to the drill.
  4. Black and Decker LDX 120C Chuck Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the five screws on the front side of the drill.
  5. Black and Decker LDX 120C Chuck Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently grab both sides of the drill casing, and separate both sides from each other.
  6. Black and Decker LDX 120C Chuck Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • At this point you should be able to separate both as illustrated.
  7. Black and Decker LDX 120C Chuck Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Now all the components of the drill are visible and can be accessed.
  8. Black and Decker LDX 120C Chuck Replacement, Chuck: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After following the prerequisite, the drill is now open.
    • The interior components can now be accessed.
  9. Black and Decker LDX 120C Chuck Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Separate the top part(the chuck and motor) from the rest of the drill.
  10. Black and Decker LDX 120C Chuck Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • While separating the top from the rest, do this carefully without over stretching the wires so that no connection is damaged.
  11. Black and Decker LDX 120C Chuck Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To remove the motor simply twist as illustrated in the picture.
  12. Black and Decker LDX 120C Chuck Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The three metal tips in the front are the ones that are controlled by the chuck to hold and release the screw.
  13. Black and Decker LDX 120C Chuck Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To test the chuck twist the head as shown in the illustration.
    • If the three metal tips don't move upon twisting then the chuck isn't working effectively and will need to be replaced since the inside of the chuck can't be accessed.
jeffrey zakka
crwdns2935283:002/09/16crwdne2935283:0
777 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 11-5, Cheng Spring 2016 crwdns2935289:0USF Tampa, Team 11-5, Cheng Spring 2016crwdne2935289:0
USFT-CHENG-S16S11G5
crwdns2942667:0crwdne2942667:0 3,106
