Black and Decker JS660 Trigger Replacement
  1. Black and Decker JS660 Trigger Replacement, Housing Disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Black and Decker JS660 Trigger Replacement, Housing Disassembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the nine torx 15.875mm screws on the front of the jigsaw using a T-15 torx screwdriver.
  2. Black and Decker JS660 Trigger Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • By separating the two housing halves, carefully remove the top plate.
  3. Black and Decker JS660 Trigger Replacement, Power Cord: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 12.7mm phillips head screws holding the power cord in place with a PH2 Phillips head screwdriver.
  4. Black and Decker JS660 Trigger Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 6.35mm flat head screws on the trigger with a 2.5 flat head screwdriver to disconnect the white and black cords.
  5. Black and Decker JS660 Trigger Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently remove the black and white cord from the trigger assembly.
  6. Black and Decker JS660 Trigger Replacement, Trigger: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use tweezers to press down on these tabs on the trigger assembly.
    • While the tab is depressed, the cord can be pulled out of the housing by using a moderate amount of force.
    • Each cord needs to be done separately.
  7. Black and Decker JS660 Trigger Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove pink wires from trigger assembly.
matt murray
crwdns2935283:001/27/17crwdne2935283:0
682 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 22-9, Maness Winter 2017 crwdns2935289:0Cal Poly, Team 22-9, Maness Winter 2017crwdne2935289:0
CPSU-MANESS-W17S22G9
crwdns2942667:0crwdne2942667:0 1,572
