Before using this device, make sure you learn how to disassemble the product from the following guide. Then, wash all the parts to extend life of the unit.
To undo the locking latches: Pull outwards at the bottom of each latch to detach them from the groove on the cover .
To remove the cover: Take out the feeder, hold the chute firmly and pull up the cover.
To remove the pulp container: Hold the juice spout with one hand and the back edge of the pulp separator with the other hand. Pull it up while making sure that the cutter/strainer is kept in place
To remove the cutter/strainer: Hold the juice spout with one hand and clutch the edge of the cutter/strainer with the other hand; pull it out slowly.
To remove the pulp separator: Hold the sides firmly and pull the container out.
To reassemble your device, follow this guide in reverse order.
