Full Device Name: Black and Decker 3-in-1 Grill - Griddle - Waffle Maker
Model Name: G48TD
This guide aims to disassemble the device into its fundamental components.
Safety warnings:
- Do not operate on device while it is receiving power
- Be careful when bending sharp metal tabs
No special skills are required for following this guide
Remove the top and bottom griddle plates.
Use a pair of Large Needle Nosed Pliers to twist the metal tabs holding the plate housing the bottom heating element connections and remove the plate.
Use a pair of Large Needle Nosed Pliers to twist the metal tabs holding the plate housing the top heating element connections and remove the plates.
Use pliers to twist the metal tabs holding down the thermostat housing.
Use a 4 mm Flathead screwdriver to remove the 11.4 mm screw in the back of the thermostat housing.
Lift up the thermostat housing and detach it from the temperature control arm, then remove the washers at the end of the temperature control arm.
Remove the thermostat housing springs.
Bend up the brackets holding down the heating elements.
Remove the heating elements from their respective housings (the bottom one is not able to be removed completely as it is fused to a piece of metal).
Remove the housing from the wiring along the bottom of the grill.
