Black and Decker FT1000 Type 1 Blower Switch Replacement
  1. Black and Decker FT1000 Type 1 Blower Switch Replacement, Black and Decker FT1000 Blower: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Black and Decker FT1000 Type 1 Blower Switch Replacement, Black and Decker FT1000 Blower: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • This is the blower. I have removed the nozzle and strap.
  2. Black and Decker FT1000 Type 1 Blower Switch Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove Screws.
  3. Black and Decker FT1000 Type 1 Blower Switch Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove rear cover. It helps to hold the plug tight to the front housing so the wires stay in place.
  4. Black and Decker FT1000 Type 1 Blower Switch Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Black and Decker FT1000 Type 1 Blower Switch Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Black and Decker FT1000 Type 1 Blower Switch Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Notice the switch is fine, it's simply the plastic armature that is broken.
    • The broken piece is only included with the motor and switch.
  5. Black and Decker FT1000 Type 1 Blower Switch Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • This switch is easy to find. It's just a single position single throw switch.
    • I was able to buy it at a home improvement store for $4.00.
    • It even fits nicely in the cutout for the original switch/armature.
  6. Black and Decker FT1000 Type 1 Blower Switch Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Black and Decker FT1000 Type 1 Blower Switch Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Black and Decker FT1000 Type 1 Blower Switch Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the switch/armature.
    • Remove the tension plate (the metal piece).
    • Put in the switch. The terminals are at a bad angle, so we will bend them to fit.
  7. Black and Decker FT1000 Type 1 Blower Switch Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Black and Decker FT1000 Type 1 Blower Switch Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Bend slowly and carefully.
    • Try it in and see how well it fits. It might need some tweaking.
  8. Black and Decker FT1000 Type 1 Blower Switch Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Black and Decker FT1000 Type 1 Blower Switch Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Now remove the actual electrical switch. No need to worry about the wiring, its just open and closed.
  9. Black and Decker FT1000 Type 1 Blower Switch Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The black wire gets a new wider terminal and just plugs on.
    • The other wire needs to be a bit longer, so it gets an extension and a new terminal.
    • I used simple crimp on terminals and splice.
  10. Black and Decker FT1000 Type 1 Blower Switch Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Black and Decker FT1000 Type 1 Blower Switch Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • There was not enough room for the terminal to pass by the plastic housing. I just removed a little and then routed the black wire under the switch.
crwdns2935229:05crwdne2935229:0
Scot Henderson
crwdns2935283:005/18/15crwdne2935283:0
857 crwdns2915208:0crwdne2915208:0
This works great. Thank you.
JFGuerrero - crwdns2934203:0crwdne2934203:0
Scot,
Thanks so much for your excellent information!!! The exact same part broke on mine today. I looked at your outstanding detail on what to do. I looked through my stash of stuff and found a toggle switch just like the one you showed but from a different manufacturer. I just got done putting it in as you described and it is better than new now. Works like a champ!
Thanks so much,
John Brodrecht
Casper, WY
John Brodrecht - crwdns2934203:0crwdne2934203:0
This was an excellent post with the perfect amount of detail and clear pictures!
I only wish you had the wiring part in the same detail because I think my wiring is faulty. I will look for your posts again for guidance. Thanks
Julie - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 45
crwdns2942667:0crwdne2942667:0 3,392
