This guide will cover the removal and replacement of the circuit board of the DCM100R coffee maker line. This guide is intended to resolve the issues of inconsistent programming and faulty buttons. Before continuing with this guide review the trouble shooting page for possible fixes.
Turn the coffee maker on its side.
Remove the four 6 mm Phillips #2 that secure the baseplate.
Insert the jimmy at the back of the panel and slide it around to the front.
Apply pressure to the backside of the panel until it releases.
Remove the plate.
Remove the two 10 mm Phillips #2 screws securing the metal support brace.
Remove the brace and set aside.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Pull back the tubing and wiring to reveal the hot plate.
Use a Phillips #2 screwdriver to remove the five 8 mm screws that secure the mounting bracket and hot plate.
Use a pair of pliers to gently pull the mounting bracket out of place.
Remove the hot plate from the mounting bracket.
Remove the O-ring from the hot plate.
Remove the two 6 mm Phillips #2 screws that secure the circuit board.
Pull the circuit board out and over the hooks.
Using the jimmy, pry the circuit board out.
Remove the two 8 mm Phillips #2 screws that hold the main circuit board.
Pull out the circuit board and disconnect the white plug.
