Black and Decker BDH9600CHV Power Switch Replacement
  1. Black and Decker BDH9600CHV Power Switch Replacement, Power Switch: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Black and Decker BDH9600CHV Power Switch Replacement, Power Switch: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Black and Decker BDH9600CHV Power Switch Replacement, Power Switch: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To remove the filter and housing, press the green button labeled "Filter".
  2. Black and Decker BDH9600CHV Power Switch Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew and remove all 5 screws using the Phillips 0 screw bit. Each screw is 17.5 mm long.
  3. Black and Decker BDH9600CHV Power Switch Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Black and Decker BDH9600CHV Power Switch Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the housing apart.
    • When you pull the housing apart, pieces may fall out. Be sure to track of the parts and where they go.
    • Remove the switch by pulling it out.
  4. Black and Decker BDH9600CHV Power Switch Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Black and Decker BDH9600CHV Power Switch Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Replace the new switch by sliding the replacement switch onto the top of the switch mechanism located on the motor.
    Where can you buy the replacement power switch?
    Bansi Shah - crwdns2934203:0crwdne2934203:0
    B&D CHV1410- I didn't locate one replacement switch, available to purchase, anywhere. But I was able to pry apart and re-align power switch slide to allow it to slide correctly to activate the electronic button switch inside the unit. I had to remove 6 screws, could not work out a way to remove the screw on the inner shroud, to split open the halves completely, but my 'no power up' situation was not really the electronic switch, so it worked out from me. The plastic slide was just a bit off track which I corrected once I could remove the upper cover for the plastic slide (I forced it up and out, and likewise back in before I closed it up and secured halves with the screws again.
    NoPro - crwdns2934203:0crwdne2934203:0
Ivette Muzquiz
crwdns2935283:011/06/17crwdne2935283:0
349 crwdns2915208:0crwdne2915208:0
IUPUI, Team S1-G4, Harley Fall 2017 crwdns2935289:0IUPUI, Team S1-G4, Harley Fall 2017crwdne2935289:0
IUPUI-HARLEY-F17S1G4
My switch with up & down button box like
Fernando Palacios - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 1,251
