Black and Decker BDERO100 Power Button Replacement
  1. Black and Decker BDERO100 Power Button Replacement, Chassis: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Black and Decker BDERO100 Power Button Replacement, Chassis: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the nylon spudger to remove the rubber ring from the filter attachment section.
    • The easiest way to do this is to place the spudger sideways and pulling out the ring.
  2. Black and Decker BDERO100 Power Button Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Black and Decker BDERO100 Power Button Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the TR20 Torx Security bit driver to unscrew the five 18.75mm Phillips screws from the warning label side of the chassis.
  3. Black and Decker BDERO100 Power Button Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Black and Decker BDERO100 Power Button Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab the plastic opening tool and place it on the separation line between both sides of the chassis.
    • Separate both sides and open the device.
    • Be careful not to lose or detach any internal parts while opening the sander.
  4. Black and Decker BDERO100 Power Button Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Black and Decker BDERO100 Power Button Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Hold the chassis and separate it from the device.
  5. Black and Decker BDERO100 Power Button Replacement, Power Button: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Black and Decker BDERO100 Power Button Replacement, Power Button: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Hold the power button and pull it out of the chassis.
  6. Black and Decker BDERO100 Power Button Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Black and Decker BDERO100 Power Button Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Select the cable that connects to the power button.
  7. Black and Decker BDERO100 Power Button Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Expose the cable and lock system by peeling off the electric cover.
    • When attaching the new power cord you will need to make sure to cover this lock system with electrical tape.
  8. Black and Decker BDERO100 Power Button Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Black and Decker BDERO100 Power Button Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push the security pin with the plastic spudger and simultaneously, pull gently on the cable to separate it from the button
  9. Black and Decker BDERO100 Power Button Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Black and Decker BDERO100 Power Button Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Detach the black wire connected to the power button from the motor. To do this, gently pull the cable while holding the power button.
Irene Zubillaga
crwdns2935283:002/10/16crwdne2935283:0
617 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 1-5, Sullivan Spring 2016 crwdns2935289:0USF Tampa, Team 1-5, Sullivan Spring 2016crwdne2935289:0
USFT-SULLIVAN-S16S1G5
I could totally do this if I could find the part. This guide is from 2016 but does anyone know from where, in 2025, this part can be sourced?
Thanks ifizit, you guys ROCK!
Tophers - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 1,228
