If your device has a faulty motor this is the guide for you. This guide is not very challenging. You may need this guide if your motor has a faulty piece, bad wiring, or failed gears. Replacing the motor can be taken care of in six simple steps.
To detach the matrix attachment piece, press down on the attachment release button located at the top of the device.
Leaving your finger pressed down on the button, simply pull on the attachment to release it.
Using a JIS 1 screwdriver, unscrew seven 19mm outer screws located on the armature.
Using the same screwdriver, unscrew the 12mm outer screw located on the armature.
Gently pull up the motor and other components at the top of the device except the handle.
Erreur de traduction : ce ne sont pas des aimants, ce sont les balais de collecteurs, appelés aussi charbons.
Slide off the the black framework on the barring side.
Remove the release button attached at the front of the motor.
Work the silver magnetic ring off of the motor through the barring end.
The motor is now free.
Hi,
Please can you tell me where to find the motor replacement part for this tool?
Thank you
I have this tool and the attachments and I absolutely love it…but I'm pretty sure the gears are stripped…do you know anything about replacing those?
