Black and Decker BDEDMT Circuit Board Replacement
  1. Black and Decker BDEDMT Circuit Board Replacement, Detach Matrix Attachment: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Black and Decker BDEDMT Circuit Board Replacement, Detach Matrix Attachment: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remember to disconnect the device from all external power sources.
    • To detach the matrix attachment piece, press down on the attachment release button located at the top of the device.
    • Leaving your finger pressed down on the button, simply pull on the attachment to release it.
  2. Black and Decker BDEDMT Circuit Board Replacement, Remove Mounting Hardware: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Black and Decker BDEDMT Circuit Board Replacement, Remove Mounting Hardware: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Black and Decker BDEDMT Circuit Board Replacement, Remove Mounting Hardware: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a JIS 1 screwdriver, unscrew seven 19mm outer screws located on the armature.
    • Using the same screwdriver, unscrew the 12mm outer screw located on the armature.
  3. Black and Decker BDEDMT Circuit Board Replacement, Circuit Board: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Black and Decker BDEDMT Circuit Board Replacement, Circuit Board: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • There will be a white cord that runs from the power cord base to the circuit board located slightly above.
    • Use the tweezers to detach the entire white cord and blue connection piece as a whole from the circuit board.
  4. Black and Decker BDEDMT Circuit Board Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Black and Decker BDEDMT Circuit Board Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Black and Decker BDEDMT Circuit Board Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • There will be one black wire, a thin white wire and a thin red wire connecting to the trigger module from the circuit board. Using your needle nose tweezers insert one of the ends into the release slot below the white wire.
    • Make sure to aim the tweezers toward the wire.
    • Lift the end of the tweezers to release the wire.
    • The Circuit board is now free.
    • Do not force the removal of the wire.
    • Remember to reinsert the wires to their corresponding slots when reassembling.
Edgardo Gutierrez Jr
crwdns2935283:001/27/16crwdne2935283:0
329 crwdns2915208:0crwdne2915208:0
UW Tacoma, Team 1-2, Rose Winter 2016 crwdns2935289:0UW Tacoma, Team 1-2, Rose Winter 2016crwdne2935289:0
UWT-ROSE-W16S1G2
crwdns2935297:011crwdne2935297:0
crwdns2936753:030crwdne2936753:0 28
crwdns2942667:0crwdne2942667:0 1,190
