Is your Bissell SpotClean ProHeat 5207U not spraying water? It could be because of a failing water pump. Follow this guide to replace the water pump for your Bissell SpotClean ProHeat 5207U.
Remove the marked 19.7 mm screws on the underside of the device using the Phillips #00 screwdriver.
Remove the plastic top located where the dirty water tank was previously situated.
Using the Phillips #00 screwdriver, unscrew the three 17.2 mm screws.
Remove the plastic lip that was previously held by the screws.
Using pliers, pinch the hose clamp tabs together, then remove the clamp.
Remove the water hose from the water pump.
Remove the green wire by pulling it away from the pump.
Pull the clear hose away from the pump until it is removed.
Remove the zip tie from the water pump.
Replace the old water pump with the new water pump.
