Bissell SpotClean ProHeat 5207U Water Pump Replacement
  1. Bissell SpotClean ProHeat 5207U Water Pump Replacement, Water Pump: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bissell SpotClean ProHeat 5207U Water Pump Replacement, Water Pump: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Ensure the device is unplugged.
    • Make sure that you have removed both the clean and dirty water tank so that you can unscrew the proper screws.
    • Remove the marked 19.7 mm screws on the underside of the device using the Phillips #00 screwdriver.
  2. Bissell SpotClean ProHeat 5207U Water Pump Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Bissell SpotClean ProHeat 5207U Water Pump Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Bissell SpotClean ProHeat 5207U Water Pump Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the plastic top located where the dirty water tank was previously situated.
    • Using the Phillips #00 screwdriver, unscrew the three 17.2 mm screws.
    • Remove the plastic lip that was previously held by the screws.
  3. Bissell SpotClean ProHeat 5207U Water Pump Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bissell SpotClean ProHeat 5207U Water Pump Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using pliers, pinch the hose clamp tabs together, then remove the clamp.
    • Remove the water hose from the water pump.
  4. Bissell SpotClean ProHeat 5207U Water Pump Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bissell SpotClean ProHeat 5207U Water Pump Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the green wire by pulling it away from the pump.
    • Be careful not to bend where the wire is plugged into.
  5. Bissell SpotClean ProHeat 5207U Water Pump Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bissell SpotClean ProHeat 5207U Water Pump Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the clear hose away from the pump until it is removed.
  6. Bissell SpotClean ProHeat 5207U Water Pump Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bissell SpotClean ProHeat 5207U Water Pump Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the zip tie from the water pump.
    • Replace the old water pump with the new water pump.
Trenton Hedgecock
crwdns2935283:009/13/23crwdne2935283:0
181 crwdns2915208:0crwdne2915208:0
University of North Texas, Team 6-4, Kilpatrick Fall 2023 crwdns2935289:0University of North Texas, Team 6-4, Kilpatrick Fall 2023crwdne2935289:0
UNT-KILPATRICK-F23S6G4
crwdns2942667:0crwdne2942667:0 477
