Bissell SpotClean ProHeat 5207U Hose Replacement
  1. Bissell SpotClean ProHeat 5207U Hose Replacement, Water Hose: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bissell SpotClean ProHeat 5207U Hose Replacement, Water Hose: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Ensure Bissell SpotClean ProHeat is unplugged
    • Position your hand vacuum so that you can see the text at the bottom saying "SpotClean ProHeat."
    • Remove the dirty water tank and the clean water tank that are located on either side.
  2. Bissell SpotClean ProHeat 5207U Hose Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Bissell SpotClean ProHeat 5207U Hose Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Bissell SpotClean ProHeat 5207U Hose Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the device so that the bottom is facing up.
    • Remove the marked 19.7 mm screws using the Phillips #00 screwdriver to remove the plastic covering.
    • Remove the plastic top located where the dirty water tank was previously situated.
    • Using the Phillips #00 screwdriver, unscrew the three screws located under the plastic cover that was previously removed.
  3. Bissell SpotClean ProHeat 5207U Hose Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bissell SpotClean ProHeat 5207U Hose Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the plastic lip that was previously held by the screws.
    • Remove the 17.2 mm screws using the Phillips #00 Screwdriver to gain access to the water pump.
  4. Bissell SpotClean ProHeat 5207U Hose Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bissell SpotClean ProHeat 5207U Hose Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the tweezers to to squeeze together the prongs of the hose clamp.
    • With the clamp squeezed, pull the hose from the pump.
    • We found it easier to pull the clamp up the hose then pull the hose from the pump.
  5. Bissell SpotClean ProHeat 5207U Hose Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the hose from the opposite end of the pump until it is fully removed.
    • Replace the previous non-working hose with a new working hose.
Zachary Chandler
crwdns2935283:009/13/23crwdne2935283:0
369 crwdns2915208:0crwdne2915208:0
University of North Texas, Team 6-4, Kilpatrick Fall 2023 crwdns2935289:0University of North Texas, Team 6-4, Kilpatrick Fall 2023crwdne2935289:0
UNT-KILPATRICK-F23S6G4
crwdns2936753:030crwdne2936753:0 47
crwdns2942667:0crwdne2942667:0 1,332
