This is a guide on how to replace the spiral brushing system on a bissell spotbot pet. Use this if your spiral brushing system is not working properly.
Remove the container on the right side of the vacuum.
Lift the tap on top of the vacuum, and then remove the container on the left side of the vacuum.
Remove the left container of the vacuum.
Remove the four screws on the top of the device.
Lift the top of the device off once the screws are removed.
Unplug the ribbon cable from the motherboard.
Separate the top piece and flip it upside down.
Remove the screws holding the motherboard in place.
Remove the motherboard from the top piece. Repair or replace the motherboard if it is faulty.
Where can I buy the part?
