For this robot vacuum, the side brushes sweep dust and debris from corners and edges that the main brush is not able to reach. If the side brushes become worn out after prolonged use, you are able to remove and replace them. This guide will show you how to replace the side brushes on your Bissell Spinwave Pet (model 3347).
Before you begin this repair, make sure to turn off your vacuum and remove it from the charging dock or charger.
Place the Bissell Spinwave pet upside down.
Use a Phillips #00 screwdriver to remove both screws.
