This guide will walk you through the process of replacing a cracked or malfunctioning brush guard on your BISSELL SpinWave Pet. The brush guard is a key component responsible for protecting the brush, allowing the device to pick up debris while remaining in place.
If your brush guard is damaged or not functioning properly, follow this guide to replace it. Before you begin this repair, ensure your BISSELL SpinWave Pet is turned off and disconnected from any power source.
make sure Bissell Spinwave is disconnected from power source
press the white button on top of the Dirt Bin
While holding the white button on top of the dirt bin, remove the dirt bin from the Bissell Spinwave pet.
flip over Bissell Spinwave pet.
Bush down on both grey buttons.
