If your device has stopped vacuuming or has weak suction, the roller brush might need to be cleaned or replaced. This replacement guide will outline the necessary steps to remove the roller brush component so it can be cleaned.
Make sure your device is powered off.
Remove plastic plate cover to reveal brush roller.
Remove brush roller from its slots on either side.
Apply pressure to one side and pull the roller out of its opposite slot.
crwdns2947412:013crwdne2947412:0
What if mine don't feel spring loaded and the brushe seems like it was just wants to fall out
I'm having the same issue. The spring is not reloading to the brush just falls out
Rachel -
Same issue with mine. Took it apart and found that the side with spring loaded holder was broken.
I am having the same issue it’s like a part is missing for the pin side not the square sides to hold the brush roll in place.
I have the same issue…it seems that the spring part was lost.have anyone of you find a replacement parts?
