If your device has stopped or slowed moving, the motor and/or tires might need to be cleaned or replaced. This replacement guide will outline the necessary steps to remove, clean, and reinstall the motor or tires component.
Lay the Bissell 1605 on its back with the stickers on the end furthest from you.
Put one finger on the wheel and the other under the access cover.
Remove the spring and carefully pull the wires out to disconnect the wheel from the socket.
