In this guide, we will demonstrate how to replace the battery pack in your SmartClean robot vacuum. The replacement process is fairly easy and no specialized tools are required.
Obtain a new battery pack from the Bissell store or by contacting support if your device is still under warranty.
Turn the power switch to the OFF position.
Gently turn the unit over.
Press on the 2 circles of the battery cover.
Slide the battery cover toward you.
Remove the old battery
