This replacement guide details how to clean or replace a filter for a Bissell PowerSwift Lightweight Compact Vacuum model 18082.
Vacuum filters keep dust and dirt from entering back into the air while vacuuming. A dirty filter does not allow for maximum air flow and suction. When your vacuum has trouble suctioning dust and dirt, this can be a sign to replace the filter instead of the entire vacuum.
Press the tank release button while pulling the tank away from the vacuum.
To detach the top of the tank where the filter is located, twist the top of the tank counterclockwise, moving the arrow from the lock symbol to the unlock symbol.
Separate the top of the tank from the bottom and remove the filter from the top of the tank.
Option 2: Clean the existing filter by placing it in a sink or bowl with 1/2 a teaspoon of dish soap and just enough warm water to cover the top of the filter.
Soak the filter for 5 minutes.
Thoroughly rinse and squeeze the filter several times to remove excess soap and water.
Place a new or newly cleaned filter into the top of the tank.
Replace the top and bottom of the tank by placing the arrow in the unlock slot and turning clockwise toward the lock picture.
Reattach the tank to the vacuum by inserting the bottom of the tank onto the vacuum base and pushing it in place until you hear a "click" sound.
