Bissell CleanView Compact 3508 Motor/Power Supply Replacement
  1. Bissell CleanView Compact 3508 Motor/Power Supply Replacement, Brush Roll Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Bissell CleanView Compact 3508 Motor/Power Supply Replacement, Brush Roll Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Bissell CleanView Compact 3508 Motor/Power Supply Replacement, Brush Roll Cover: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With the vacuum in an upright position, press the latch on the rear of the spine to remove the handle from the vacuum.
  2. Bissell CleanView Compact 3508 Motor/Power Supply Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bissell CleanView Compact 3508 Motor/Power Supply Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #2 screwdriver to remove the five 20.7 mm screws on the underside of the brush roll cover.
  3. Bissell CleanView Compact 3508 Motor/Power Supply Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Bissell CleanView Compact 3508 Motor/Power Supply Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Bissell CleanView Compact 3508 Motor/Power Supply Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a pry tool or flathead screwdriver to disengage the two retaining clips securing the brush roll cover.
    • Remove the brush roll cover.
  4. Bissell CleanView Compact 3508 Motor/Power Supply Replacement, Top/Bottom: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Bissell CleanView Compact 3508 Motor/Power Supply Replacement, Top/Bottom: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Bissell CleanView Compact 3508 Motor/Power Supply Replacement, Top/Bottom: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the main black hose from its lower attachment point.
  5. Bissell CleanView Compact 3508 Motor/Power Supply Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #2 screwdriver to remove the two 20.7 mm screws from the lower hose attachment point.
  6. Bissell CleanView Compact 3508 Motor/Power Supply Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Bissell CleanView Compact 3508 Motor/Power Supply Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Bissell CleanView Compact 3508 Motor/Power Supply Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #2 screwdriver to remove the four 20.7 mm screws on the upper cover plates.
    • Remove the two upper cover plates.
  7. Bissell CleanView Compact 3508 Motor/Power Supply Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Bissell CleanView Compact 3508 Motor/Power Supply Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Bissell CleanView Compact 3508 Motor/Power Supply Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently pull the top half up and to the side away from the drive shaft to separate both halves.
    • Pull the belt through the socket, and remove the belt from the drive shaft.
  8. Bissell CleanView Compact 3508 Motor/Power Supply Replacement, Motor: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bissell CleanView Compact 3508 Motor/Power Supply Replacement, Motor: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push the button on the canister to remove it from the spine.
    • Set the canister to the side.
  9. Bissell CleanView Compact 3508 Motor/Power Supply Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Bissell CleanView Compact 3508 Motor/Power Supply Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Bissell CleanView Compact 3508 Motor/Power Supply Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the one 20.7 mm screw with a Phillips #2 screwdriver.
    • Separate the spine from the motor.
  10. Bissell CleanView Compact 3508 Motor/Power Supply Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bissell CleanView Compact 3508 Motor/Power Supply Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 2.7 mm screws with a Phillips #2 screwdriver.
    • Press down on the red lever to access another 20.7mm screw. Remove the screw with a Phillips #2 screwdriver.
  11. Bissell CleanView Compact 3508 Motor/Power Supply Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Bissell CleanView Compact 3508 Motor/Power Supply Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Bissell CleanView Compact 3508 Motor/Power Supply Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Separate the halves.
    • Take care not to strain the connected cables.
    • Unwind the power cable from its post, and gently pull the motor out of the casing.
  12. Bissell CleanView Compact 3508 Motor/Power Supply Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Bissell CleanView Compact 3508 Motor/Power Supply Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Bissell CleanView Compact 3508 Motor/Power Supply Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • By taking the motor out of its casing, the cover of the switch becomes exposed.
    • Use a Phillips #2 screwdriver to remove the 20.7 mm screw from the cover.
    • Gently remove the cover.
  13. Bissell CleanView Compact 3508 Motor/Power Supply Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bissell CleanView Compact 3508 Motor/Power Supply Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently disconnect the motor from the connector.
    • Remove the motor.
Everett Harrison
crwdns2935283:002/19/25crwdne2935283:0
873 crwdns2915208:0crwdne2915208:0
University of Memphis, Team 1-4, Sneed Spring 2025 crwdns2935289:0University of Memphis, Team 1-4, Sneed Spring 2025crwdne2935289:0
UM-SNEED-S25S1G4
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 73
