This guide for the Bissell CleanView Compact 3508 will give you step-by-step instructions to replace the base plate at the bottom of your vacuum. This piece simply covers up some of the vacuums internals to protect it.
With the vacuum in an upright position, press the latch on the rear of the spine to remove the handle from the vacuum.
Use a Phillips #2 screwdriver to remove the five 20.7 mm screws on the underside of the brush roll cover.
Use a pry tool or flathead screwdriver to disengage the two retaining clips securing the brush roll cover.
Remove the brush roll cover.
