Bionaire BDF1214CR-CN Fan Blade Replacement
  1. Bionaire BDF1214CR-CN Fan Blade Replacement, Fan Blade: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Bionaire BDF1214CR-CN Fan Blade Replacement, Fan Blade: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Bionaire BDF1214CR-CN Fan Blade Replacement, Fan Blade: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unplug the fan and switch it off.
  2. Bionaire BDF1214CR-CN Fan Blade Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Bionaire BDF1214CR-CN Fan Blade Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Bionaire BDF1214CR-CN Fan Blade Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip open the clip locks positioned along the seam of the housing or cage.
  3. Bionaire BDF1214CR-CN Fan Blade Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Bionaire BDF1214CR-CN Fan Blade Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Bionaire BDF1214CR-CN Fan Blade Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the Phillips #2 screwdriver to loosen the 7 mm screw at the bottom of the grill.
    • When the 7 mm Phillips #2 screw is loose, turn to the back of the fan and rotate the small bolt counterclockwise until it pops out.
    • Remove the 7 mm Phillips #2 screw.
  4. Bionaire BDF1214CR-CN Fan Blade Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Bionaire BDF1214CR-CN Fan Blade Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Bionaire BDF1214CR-CN Fan Blade Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the front housing upward to remove it from the fan.
    • You might need a little bit of force to remove it.
  5. Bionaire BDF1214CR-CN Fan Blade Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Bionaire BDF1214CR-CN Fan Blade Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Bionaire BDF1214CR-CN Fan Blade Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Rotate the fan blade until the 6 mm Phillips #2 screw behind the blade is pointing upwards.
    • Use the Phillips #2 screwdriver to remove the 6 mm screw
    • Use the 6 mm flathead screwdriver to remove the screw if you have difficulty removing it using the Phillips #2 screwdriver.
  6. Bionaire BDF1214CR-CN Fan Blade Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Bionaire BDF1214CR-CN Fan Blade Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Bionaire BDF1214CR-CN Fan Blade Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the fan blade straight off of the rotor to remove it.
  7. Bionaire BDF1214CR-CN Fan Blade Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bionaire BDF1214CR-CN Fan Blade Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Position the new fan blade where the dents are faced upward and the 6 mm Phillips #2 screw on the fan blade is also pointed upwards.
    • Slide the fan blade onto the rotor.
    • Use a Phillips #2 screwdriver to tighten the screw.
    • To test if it's tightened, gently tug the fan blade toward you. If it does not budge, then it is tight enough.
To reassemble your device, follow these instructions in reverse order starting from Step 4.
Zoe
crwdns2935283:001/29/25crwdne2935283:0
145 crwdns2915208:0crwdne2915208:0
York University, Team 4-11, Woodhouse Winter 2025 crwdns2935289:0York University, Team 4-11, Woodhouse Winter 2025crwdne2935289:0
YORK-WOODHOUSE-W25S4G11
crwdns2942667:0crwdne2942667:0 249
