This guide will show the user how to access the air filter for inspection and/or removal. This guide is a prerequisite for removing the outer shell, and requires the removal of the base of the Bionaire BAP 600.
Rotate base counterclockwise, supporting top with opposite hand.
Pull base away from housing exposing air filter.
Grab the edge of the filter housing and pull the filter away from the rest of the device.
Gently pull apart each fold of the filter to check for abrasions or other anomalies. Clean with a dust rag if necessary.
Bonjour.merci pour le tutoriel,mais où trouver un filtre…
Where such a filter can be bought? I was in Italy when I order mine from Amazon (UK) but can't find the filter to replace, I damaged mine.
Any idea?
I been searching for 3 years now. They don't make them. You have to buy a new one. I went to Honeywell and not had a problem.
Blake PS -
