Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement
  1. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement, Throttle Cable: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement, Throttle Cable: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement, Throttle Cable: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Cut and remove any zip ties securing the throttle cable.
  2. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #2 driver to remove the screw securing the lower end of the throttle cable.
  3. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the bracket securing the lower end of the throttle cable.
  4. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Rotate the lower end of the throttle cable to detach it from the throttle.
  5. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • When reinstalling the throttle control cable, check to make sure that the throttle control moves the throttle through its full range of motion.
    • If necessary, loosen the screw securing the lower end of the throttle cable and adjust the position of the cable. Re-tighten the screw and check to make sure that the throttle moves through its full range of motion.
  6. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a 7/16" wrench or deep socket to remove the cap from the throttle control.
  7. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Advance the throttle control to expose the gear rack containing the upper end of the throttle cable.
  8. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Separate the gear rack from the upper end of the throttle cable.
    • Lift and remove the gear rack from the throttle control.
    • If the gear rack doesn't fully detach, advance the throttle control lever a little farther.
    • Lubricate the gear rack with a bit of lithium grease during reassembly.
  9. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a 1/2" wrench to unscrew the upper end of the throttle cable from the throttle control.
    • Slide the throttle cable down out of the bottom of the throttle control, and remove the cable.
  10. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement, Throttle Control: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement, Throttle Control: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #2 driver to remove the two screws securing the throttle control.
    • While removing the screws, use a 3/8" wrench to counter-hold the lock nuts and prevent them from rotating.
  11. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the throttle control.
Jeff Suovanen
crwdns2935283:008/06/13crwdne2935283:0
443,014 crwdns2915208:0crwdne2915208:0
crwdns2935297:0259crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021,719crwdne2935297:0
the part # is incorrect, it appears that it is 440014 not 440013
JACOB - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 1,189
