Billy Goat Brush Cutter BC2600HHF 2015 Blade (Spindle) Belt Replacement
  1. Billy Goat Brush Cutter BC2600HHF 2015 Blade (Spindle) Belt Replacement, Spark Plug Disconnection: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Billy Goat Brush Cutter BC2600HHF 2015 Blade (Spindle) Belt Replacement, Spark Plug Disconnection: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  2. Billy Goat Brush Cutter BC2600HHF 2015 Blade (Spindle) Belt Replacement, Rear Guard: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 1/2" socket or wrench to remove the two 26 mm bolts securing the rear guard to the back end of the brush cutter.
  3. Billy Goat Brush Cutter BC2600HHF 2015 Blade (Spindle) Belt Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Billy Goat Brush Cutter BC2600HHF 2015 Blade (Spindle) Belt Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The brush cutter is heavy—get help before attempting to lift it.
    • If you choose to tip the brush cutter onto its side, first drain the oil and gas.
    • Raise and support the back end of the brush cutter—or tip it carefully onto its side—in order to access the bottom cover.
  4. Billy Goat Brush Cutter BC2600HHF 2015 Blade (Spindle) Belt Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Billy Goat Brush Cutter BC2600HHF 2015 Blade (Spindle) Belt Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Billy Goat Brush Cutter BC2600HHF 2015 Blade (Spindle) Belt Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a 3/8” socket or wrench to remove the four 21 mm bolts securing the rear guard.
    • Remove the guard.
  5. Billy Goat Brush Cutter BC2600HHF 2015 Blade (Spindle) Belt Replacement, Transaxle Drive Belt: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Billy Goat Brush Cutter BC2600HHF 2015 Blade (Spindle) Belt Replacement, Transaxle Drive Belt: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Billy Goat Brush Cutter BC2600HHF 2015 Blade (Spindle) Belt Replacement, Transaxle Drive Belt: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Relieve the tension on the transaxle drive belt by pressing on the back end of the tensioning arm. (Alternatively, use a pry bar on the front end of the tensioning arm, or remove the tensioning spring.)
    • Slip the transaxle drive belt off the drive pulley.
  6. Billy Goat Brush Cutter BC2600HHF 2015 Blade (Spindle) Belt Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Billy Goat Brush Cutter BC2600HHF 2015 Blade (Spindle) Belt Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Billy Goat Brush Cutter BC2600HHF 2015 Blade (Spindle) Belt Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Free the belt by sliding it out between the transaxle pulley and the spindle belt.
    • Remove the transaxle drive belt.
  7. Billy Goat Brush Cutter BC2600HHF 2015 Blade (Spindle) Belt Replacement, Belt Deck Cover: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Billy Goat Brush Cutter BC2600HHF 2015 Blade (Spindle) Belt Replacement, Belt Deck Cover: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Billy Goat Brush Cutter BC2600HHF 2015 Blade (Spindle) Belt Replacement, Belt Deck Cover: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a 3/8" socket or wrench to remove the four 21 mm bolts securing the cover to the deck—two at the front, and one on each side.
  8. Billy Goat Brush Cutter BC2600HHF 2015 Blade (Spindle) Belt Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Billy Goat Brush Cutter BC2600HHF 2015 Blade (Spindle) Belt Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift and remove the belt deck cover.
  9. Billy Goat Brush Cutter BC2600HHF 2015 Blade (Spindle) Belt Replacement, Blade (Spindle) Belt: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Billy Goat Brush Cutter BC2600HHF 2015 Blade (Spindle) Belt Replacement, Blade (Spindle) Belt: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Billy Goat Brush Cutter BC2600HHF 2015 Blade (Spindle) Belt Replacement, Blade (Spindle) Belt: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a 3/8" drive ratchet (without any socket attached) into the square cutout in the middle of the deck idler arm.
    • A short extension is helpful but not required.
    • Crank the ratchet clockwise to relieve the tension on the belt.
  10. Billy Goat Brush Cutter BC2600HHF 2015 Blade (Spindle) Belt Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slip the belt off the deck pulley.
  11. Billy Goat Brush Cutter BC2600HHF 2015 Blade (Spindle) Belt Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Billy Goat Brush Cutter BC2600HHF 2015 Blade (Spindle) Belt Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Billy Goat Brush Cutter BC2600HHF 2015 Blade (Spindle) Belt Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slip the other end of the belt off the drive pulley.
    • Pull to thread the belt through the slot in the deck, and remove the belt.
Jeff Suovanen
crwdns2935283:008/06/13crwdne2935283:0
442.336 crwdns2915208:0crwdne2915208:0
crwdns2935297:0259crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021.019crwdne2935297:0
crwdns2936753:030crwdne2936753:0 67
crwdns2942667:0crwdne2942667:0 3,432
