Bicycle Handlebar Grip Rubber Grips on the Handlebars Replacement
  1. Bicycle Handlebar Grip Rubber Grips on the Handlebars Replacement, Rubber Grips on the Handlebars: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Put the straw of the air canister under the grip.
    • Pinch the end (can be done with pliers), and use the gap created to slip the straw in.
    • To separate the grip, you may use a screwdriver or another long, skinny tool allowing you to gain leverage underneath the grip.
    • While spraying air underneath the grips, pull on the grips with enough force to move them off the handlebar.
    • The air will separate the grips from the handlebars.
    • If more force is needed, you may use an air compressor with a needle attachment.
  2. Bicycle Handlebar Grip Rubber Grips on the Handlebars Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bicycle Handlebar Grip Rubber Grips on the Handlebars Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Spray the handlebar and inside the grip with your hairspray or lubricant/adhesive.
    • Slide the grips all the way on until there's no more room for the grips to slide on.
    • I use hairspray because it is both a lubricant and an adhesive. Other combos can be WD-40 and super glue.
    • If your handlebar is dirty or you want to clean it, use warm soap and water to clean it with a wash cloth.
  3. Bicycle Handlebar Grip Rubber Grips on the Handlebars Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the new grips on.
    • Let them dry.
    • Put your brakes and shifting levers back on.
    • Finally, enjoy the new grips!
In order to move or replace these grips follow these steps from top to bottom.
Phoenix Gavin-Scott Hanks Jr.
crwdns2935283:002/04/19crwdne2935283:0
97 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team S27-G11, Munoz Winter 2019 crwdns2935289:0Eastern Washington University, Team S27-G11, Munoz Winter 2019crwdne2935289:0
EWU-MUNOZ-W19S27G11
crwdns2942667:0crwdne2942667:0 788
