Bicycle Cassette Replacement
  1. Bicycle Cassette Replacement, Bicycle Cassette: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bicycle Cassette Replacement, Bicycle Cassette: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place your wheel on a hard surface with the cassette on your right side.
    • Wrap the chain whip clockwise around the cassette.
  2. Bicycle Cassette Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Bicycle Cassette Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Bicycle Cassette Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the cassette lockring tool into the center of the cassette with the lever arm between 7 and 9 o'clock.
    • Holding the chain whip in place with your left hand, apply counterclockwise force on the cassette tool's lever arm.
    • Continue turning the cassette tool until the tool spins freely.
  3. Bicycle Cassette Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Bicycle Cassette Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Bicycle Cassette Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lay the wheel down on a flat surface with the cassette facing upwards.
    • Loosen the cassette lockring by turning it counterclockwise.
  4. Bicycle Cassette Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Bicycle Cassette Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Bicycle Cassette Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the cassette lockring.
    • Using both hands, lift the cassette in one piece from the freehub body.
  5. Bicycle Cassette Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bicycle Cassette Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Your cassette may require a spacer to work properly with your freehub. Consult your cassette user's manual to determine your spacer needs.
    • Remove the old freehub body spacer as needed.
  6. Bicycle Cassette Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Bicycle Cassette Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Bicycle Cassette Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the small cutout on the bottom of the new cassette.
    • Locate the small ridge on the freehub body.
    • Slide the bottom piece of the new cassette on the freehub body by matching the small cutout with the small ridge.
  7. Bicycle Cassette Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Bicycle Cassette Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Bicycle Cassette Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Continue placing smaller cogs on the freehub body by matching the cutouts and ridges.
    • Insert spacers as specified by the cassette user's manual.
  8. Bicycle Cassette Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Bicycle Cassette Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Bicycle Cassette Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • For the final two cogs, locate the small cutouts and place on top of the already placed cogs by aligning with the top of small ridge on the freehub body.
    • The top two cogs will not fully slide on to the freehub body and require more attention for aligned placement.
  9. Bicycle Cassette Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bicycle Cassette Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the cassette lockring onto the top of the final cog.
    • Start threading the lockring clockwise into the freehub by hand.
  10. Bicycle Cassette Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Bicycle Cassette Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Bicycle Cassette Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once the lockring is partially threaded in, insert the cassette lockring tool.
    • Tighten the cassette on the freehub body by turning the lockring tool clockwise.
    • The exact torque to tighten to varies by cassette manufacturer and model. Consult the cassette user's manual.
    • After finishing tightening, check the cassette for play by pulling up on the largest cog. If excess play is present and the cassette has been tightened to specifications, a spacer is likely missing.
Lars Lundqvist
crwdns2935283:004/14/25crwdne2935283:0
208 crwdns2915208:0crwdne2915208:0
UC Davis, Team 1-5, Morris Spring 2025 crwdns2935289:0UC Davis, Team 1-5, Morris Spring 2025crwdne2935289:0
UCD-MORRIS-S25S1G5
crwdns2936753:030crwdne2936753:0 72
crwdns2942667:0crwdne2942667:0 321
