Benchmade Griptillian Disassembly
    1. Benchmade Griptillian Disassembly, Close the blade and turn the knife to the side that has the belt clip: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Be sure to make note of what side the belt clip is on for reassembly.
    2. Benchmade Griptillian Disassembly, Remove screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a T6 bit to remove the two screws holding the belt clip.
    3. Benchmade Griptillian Disassembly, Remove T6 Screws: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use the T6 bit to remove the four screws holding the handle in place.
    4. Benchmade Griptillian Disassembly, Turn the knife over: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Turn the knife over and remove one T6 screw.
    5. Benchmade Griptillian Disassembly, Remove the T8 screw: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Turn the knife over and remove the T8 screw that is going through the hinge.
    6. Benchmade Griptillian Disassembly, Remove the handle: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Once you've removed the screw, you can remove the handle.
    7. Benchmade Griptillian Disassembly, Drive pin out of the other handle: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using the T6 bit, drive the hinge pin out of the other handle.
    8. Benchmade Griptillian Disassembly, Remove the other handle: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Once you've done this you can remove the other handle.
    9. Benchmade Griptillian Disassembly, Slide the blade out of the frame: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Be sure to keep both brass washers. Sometimes they will stick to the frame or the blade.
    10. Benchmade Griptillian Disassembly, Sand both sides of copper: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using 600 grit sandpaper and a flat surface, rub both sides of the copper washers until there is new material showing.
    11. Benchmade Griptillian Disassembly, Reverse process to re assemble: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Reverse process to re assemble.
Spin Modder
crwdns2935283:007/21/22crwdne2935283:0
256 crwdns2915208:0crwdne2915208:0
crwdns2936753:07crwdne2936753:0 32
crwdns2936753:030crwdne2936753:0 84
crwdns2942667:0crwdne2942667:0 1,693
