How to reset the clock to get the oven working.
Hold down either the first or first two buttons (depending on the model).
Use the arrow buttons to set the clock (It always starts at 12:00).
What if the buttons stopped working? I can’t press them down.
Update:
I can press them down like I normally can but the clock won’t change and the time stays as it is. I can only use the top oven.
Something that worked with my Blomberg and may help is to turn off the power to the oven, wait 10 seconds and then turn the power back on - the oven then behaves as though it is being newly installed, the clock resets to 12.00, and should be re-settable. Good luck
Where can I get new oven seal??
komand.oo - crwdns2934203:0crwdne2934203:0
