Bella Pro 90246 Light Bulb Replacement
  1. Bella Pro 90246 Light Bulb Replacement, Light Bulb: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure your air fryer is unplugged to avoid the risk of being electrocuted.
    • Gather your materials to begin disassembly.
  2. Bella Pro 90246 Light Bulb Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Bella Pro 90246 Light Bulb Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Bella Pro 90246 Light Bulb Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the metal spudger to pry off the protective lid on all four sides.
  3. Bella Pro 90246 Light Bulb Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bella Pro 90246 Light Bulb Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the three 9.5 mm screws on the top of the air fryer that hold the plastic cover in place using a Phillips #1 screwdriver.
  4. Bella Pro 90246 Light Bulb Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Bella Pro 90246 Light Bulb Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Bella Pro 90246 Light Bulb Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the Phillips #1 screwdriver to remove the four 34.9 mm screws that are located inside the round holes on the corners of the plastic cover.
    • You may need to use a pair of needle nose pliers to remove the screws from the deep set holes.
  5. Bella Pro 90246 Light Bulb Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bella Pro 90246 Light Bulb Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open the door.
  6. Bella Pro 90246 Light Bulb Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Bella Pro 90246 Light Bulb Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Bella Pro 90246 Light Bulb Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Press the button underneath the hood to release the mechanism that holds the door in place.
    • Once the door is disconnected, remove it from the airfryer and set it to the side.
  7. Bella Pro 90246 Light Bulb Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bella Pro 90246 Light Bulb Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully tilt the air fryer onto its side.
  8. Bella Pro 90246 Light Bulb Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Bella Pro 90246 Light Bulb Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Bella Pro 90246 Light Bulb Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the Phillips #1 screwdriver to remove the three 25.4 mm screws under the hood.
  9. Bella Pro 90246 Light Bulb Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Hold the top of the air fryer into place while carefully moving it back to its up-right position.
    • After removing the screws, the top will be loose. Hold firmly to avoid damage to any wire connections underneath the plastic cover.
  10. Bella Pro 90246 Light Bulb Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Bella Pro 90246 Light Bulb Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Bella Pro 90246 Light Bulb Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Identify the grey electrical cable attached to the circuit board.
    • Press firmly on the cable head's tab to release the connection.
    • Carefully wiggle the cable head to disconnect the wire from the circuit board without damaging it.
  11. Bella Pro 90246 Light Bulb Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bella Pro 90246 Light Bulb Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the top cover off of the air fryer to access the electrical circuits underneath.
  12. Bella Pro 90246 Light Bulb Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Bella Pro 90246 Light Bulb Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Bella Pro 90246 Light Bulb Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two 19.1 mm screws securing the metal light bulb cover using a Phillips #1 screwdriver.
    • Carefully pull off the metal cover to reveal the burnt-out light bulb.
  13. Bella Pro 90246 Light Bulb Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Bella Pro 90246 Light Bulb Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Bella Pro 90246 Light Bulb Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The light bulb is made of glass and can be fragile. Handle with care to avoid injuring yourself with broken shards of glass.
    • Lift the light bulb circuit out of the plastic slot and remove the burnt out light bulb by pulling gently.
  14. Bella Pro 90246 Light Bulb Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Bella Pro 90246 Light Bulb Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Bella Pro 90246 Light Bulb Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently plug the new light bulb into the light bulb circuit.
  15. Bella Pro 90246 Light Bulb Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bella Pro 90246 Light Bulb Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the light bulb circuit carefully back into the plastic slot.
  16. Bella Pro 90246 Light Bulb Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bella Pro 90246 Light Bulb Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Plug your air fryer into an electrical outlet to confirm your new light bulb works.
    • Enjoy your perfectly cooked food!
To reassemble your device follow this guide in reverse order starting with step 11.
Nattaly Vargas
crwdns2935283:002/21/25crwdne2935283:0
271 crwdns2915208:0crwdne2915208:0
UC Davis, Team 1-5, Andersen Winter 2025 crwdns2935289:0UC Davis, Team 1-5, Andersen Winter 2025crwdne2935289:0
UCD-ANDERSEN-W25S1G5
Can I please get a picture of the circuit board from both sides? I plugged this air fryer in 220 volts, which might've caused a couple resistors to go bad and I am trying to replace them, but I don't know the exact value of them
AbdulRaheem - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 53
crwdns2942667:0crwdne2942667:0 266
