Bella 4-Slice Toaster Oven Temperature Dial Replacement
  1. Bella 4-Slice Toaster Oven Temperature Dial Replacement, Outer Shell: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove five 11.6 mm Phillips #2 screws from the rear of the device.
  2. Bella 4-Slice Toaster Oven Temperature Dial Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open the front glass door of the toaster oven.
  3. Bella 4-Slice Toaster Oven Temperature Dial Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate retaining screw on the upper-middle portion of the door frame.
  4. Bella 4-Slice Toaster Oven Temperature Dial Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove one 21.9 mm Phillips #2 retaining screw from upper-middle portion of door frame.
  5. Bella 4-Slice Toaster Oven Temperature Dial Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip toaster onto back panel with feet facing forward.
  6. Bella 4-Slice Toaster Oven Temperature Dial Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use spudger to pry the grey rubber inserts from the black plastic feet.
  7. Bella 4-Slice Toaster Oven Temperature Dial Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove four 13.7mm Phillips #2 screws from black plastic feet to separate the cover from the device.
  8. Bella 4-Slice Toaster Oven Temperature Dial Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the black outer cover off of the toaster
  9. Bella 4-Slice Toaster Oven Temperature Dial Replacement, Temperature Dial: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a plastic spudger, gently pry the black plastic temperature dial away from the face of the toaster.
  10. Bella 4-Slice Toaster Oven Temperature Dial Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove two 5.91 mm #2 Phillips screws which secure the inner component to the toaster.
  11. Bella 4-Slice Toaster Oven Temperature Dial Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Inside the device, unplug the red wire connecting the black plastic part of the dial to the heating element.
  12. Bella 4-Slice Toaster Oven Temperature Dial Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Now unplug the other red wire from the black plastic part of the dial.
  13. Bella 4-Slice Toaster Oven Temperature Dial Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the two white wires from the metal part of the dial.
  14. Bella 4-Slice Toaster Oven Temperature Dial Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the dial from device interior.
Pierce Hampton
crwdns2935283:001/31/19crwdne2935283:0
561 crwdns2915208:0crwdne2915208:0
Appalachian State University, Team S1-G4, Menagarishvili Spring 2019 crwdns2935289:0Appalachian State University, Team S1-G4, Menagarishvili Spring 2019crwdne2935289:0
APSU-MENAGARISHVILI-S19S1G4
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 561
