Bella 4-Slice Toaster Oven Glass Door Replacement
  1. Bella 4-Slice Toaster Oven Glass Door Replacement, Outer Shell: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove five 11.6 mm Phillips #2 screws from the rear of the device.
  2. Bella 4-Slice Toaster Oven Glass Door Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open the front glass door of the toaster oven.
  3. Bella 4-Slice Toaster Oven Glass Door Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate retaining screw on the upper-middle portion of the door frame.
  4. Bella 4-Slice Toaster Oven Glass Door Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove one 21.9 mm Phillips #2 retaining screw from upper-middle portion of door frame.
  5. Bella 4-Slice Toaster Oven Glass Door Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip toaster onto back panel with feet facing forward.
  6. Bella 4-Slice Toaster Oven Glass Door Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use spudger to pry the grey rubber inserts from the black plastic feet.
  7. Bella 4-Slice Toaster Oven Glass Door Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove four 13.7mm Phillips #2 screws from black plastic feet to separate the cover from the device.
  8. Bella 4-Slice Toaster Oven Glass Door Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the black outer cover off of the toaster
  9. Bella 4-Slice Toaster Oven Glass Door Replacement, Glass Door: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bella 4-Slice Toaster Oven Glass Door Replacement, Glass Door: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unhook the black coil springs from back of the toaster on both sides of the device.
  10. Bella 4-Slice Toaster Oven Glass Door Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the black spudger to gently depress the hinge prongs on the bottom of the door.
  11. Bella 4-Slice Toaster Oven Glass Door Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bella 4-Slice Toaster Oven Glass Door Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently slide door away from the device, removing it from the device.
Pierce Hampton
crwdns2935283:001/31/19crwdne2935283:0
561 crwdns2915208:0crwdne2915208:0
Appalachian State University, Team S1-G4, Menagarishvili Spring 2019 crwdns2935289:0Appalachian State University, Team S1-G4, Menagarishvili Spring 2019crwdne2935289:0
APSU-MENAGARISHVILI-S19S1G4
crwdns2942667:0crwdne2942667:0 1,128
