crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Belkin F5L009 Network USB Hubcrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Belkin F5L009 Network USB Hub Teardown, Belkin F5L009 Network USB Hub Teardown: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pictured here is the Belkin F5L009, along with a plastic opening tool and a #1 Philips (at least so the head says...), which were the only tools I needed to do this. A guitar pick or other thin, flat, plastic object might work instead of an opening tool; I didn't test it.
  2. Belkin F5L009 Network USB Hub Teardown: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Belkin F5L009 Network USB Hub Teardown: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • I began by flipping the F5L009 upside down.
    • The case is held together by small tabs all along the sides. Work the spudger between where the two halves meet. I started on the side with the ethernet port, since it seemed to be the most flexible.
    • Once you get a bit of the top and bottom halves separated on one side, start sliding the opening tool around the entire case until all the tabs are disengaged. I found them to be rather "soft" and easy to disengage without breaking them.
  3. Belkin F5L009 Network USB Hub Teardown: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Belkin F5L009 Network USB Hub Teardown: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully flip the device back onto its belly and lift the top off the bottom.
    • When I performed this teardown, I encountered a tiny piece of plastic over the indicator LED that fell off upon my removal of the top of the case.
  4. Belkin F5L009 Network USB Hub Teardown: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Belkin F5L009 Network USB Hub Teardown: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Strangely, though there are three holes available for screws, I found only two screws actually holding the mainboard to the bottom half of the case. Unscrewing them both was all it took to get the mainboard free.
    • Underneath the two screwholes down the middle of the device are tiny plastic spacers. Don't lose those.
  5. Belkin F5L009 Network USB Hub Teardown: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The mainboard has four big integrated circuits worth mentioning. Three of their datasheets are attached to this guide for reference.
    • The Micrel "Centaur" KSZ8695PX in the upper-left is an ARM-based system-on-chip. Specifically, it features a single 166MHz 32-bit ARM9 core, support for up to 64MB of combined RAM and ROM, and built-in ethernet and PCI interfaces.
    • The datasheet makes it apparent that this chip was intended to use that PCI interface with a wireless networking card or chipset for use in a wireless router or something similar.
    • The big chip off to the right is an NEC D720101GJ, which is normally used on standalone PCI USB cards like the Belkin F5U220, indicating that the chip is part of a PCI-driven USB chipset built right into the mainboard. The chip supports up to 6 USB 2.0 ports (from what I can tell by the features of cards using it), but only five are used.
    • The chip on the bottom left is an Excel Semiconductor ES29LV160D 16Mbit (2MB) flash memory module. Supposedly, this stores some kind of modified Linux; I contacted Belkin asking about obtaining firmware source code, but haven't received a response yet...
    • Last but not least, in the bottom-middle, is a Winbond W9812G2GH SDRAM module. It has a capacity of "1,048,576 words x 4 banks x 32 bits", which - if I'm reading that right - translates to roughly 2MB of RAM (it's either 2MB divided into 4 banks or 4 banks of 2MB each; the datasheet's pretty vague).
    • When combined with the above-mentioned flash memory, that's a whopping 4MB of combined RAM and ROM - leaving about 60MB of wiggle room if someone wanted to solder on bigger memory modules.
Ryan Northrup
crwdns2935283:009/13/12crwdne2935283:0
364 crwdns2915208:0crwdne2915208:0
Lahontan Systems crwdns2935289:0Lahontan Systemscrwdne2935289:0
Business
Is there any chance of uploading some alternative firmware and turning it into a headless Linux box?
eugrus - crwdns2934203:0crwdne2934203:0
Brony? Or MLP fan?
Anyways, nice guide. Appreciated!
Alex Li - crwdns2934203:0crwdne2934203:0
I think it has 2mb of flash and 16mb ram. Looks like its running an RTOS with a debugger on the serial port ( pins labelled T and R - 9600 baud )
Hello, this is CREAM for KS8695P!!
'CAKE' CREAM Kernel debugger Ver 1.4.2
'HeDEB' Heap debugger Ver 1.0.0
'DISH' Debugging shell Version 2.5.0
DISH>SYSLOG SysLog Level:4
EEPROM WriteCount: EEP1=1 EEP2=2
MAC address 00:1C:DF:FE:AD:8D
Address :
03004000:Erase
03006000:
oooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo
EEPROM Write!! ***** NIC Initialize Start *****
NIC:TxRx Stop
NIC:MAC Reset
NIC: Initialize Start>>>
NIC: CAM is Dsiable
aNIC:PHY Mode...[00]<<
bcdef..ghi.....<
j<<OKNIC:Packet Task Start!!
PHY:Initialize Start
PHY:PHY ID[86950001]:MICREL KS8695P<
PHY:PHY Setup...<
NIC:TxRx Start
PHY:Link Wait...PHY:10/100 Check START!!
NIC:Polling Task Start!!
PHY:TRC Task Start!!
Oli - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 6,855
