Bed Head Wave Artist Deep Waver Lower Handle Housing Replacement
  1. Bed Head Wave Artist Deep Waver Lower Handle Housing Replacement, Lower Handle Housing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bed Head Wave Artist Deep Waver Lower Handle Housing Replacement, Lower Handle Housing: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before disassembling your Deep Waver, be sure to unplug the device to avoid electric shock, and make sure the heating elements of the device are cool to avoid burns.
    • Unlock the handle of your Deep Waver to gain access to the screws you need to remove.
    • Remove two 10 mm Phillips #01 screws from the lower handle housing.
    • Remove one 10 mm Phillips #02 screw from the lower handle housing.
  2. Bed Head Wave Artist Deep Waver Lower Handle Housing Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry the black screw cover off the side of the lower handle housing using a fine-point spudger or pick. This side will have the model number and other product information embossed on it.
  3. Bed Head Wave Artist Deep Waver Lower Handle Housing Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove one 10 mm Phillips 1 screw from the handle joint.
  4. Bed Head Wave Artist Deep Waver Lower Handle Housing Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry the black screw cover off the other side of the lower handle housing. This side will have the power switch located on it.
  5. Bed Head Wave Artist Deep Waver Lower Handle Housing Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Cut along the length of the black housing retainer with a rotary tool to split and remove the retainer.
  6. Bed Head Wave Artist Deep Waver Lower Handle Housing Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Split the lower handle housing apart using a plastic opening tool.
    • Begin splitting the housing at one end rather than the center to avoid cracking the casing.
To reassemble your device, follow these instructions in reverse order. Once each half of the housing have been put back together, install a new Housing Retainer to replace the one you cut off.
Grant Peters
crwdns2935283:011/06/17crwdne2935283:0
401 crwdns2915208:0crwdne2915208:0
IUPUI, Team S6-G3, Baechle Fall 2017 crwdns2935289:0IUPUI, Team S6-G3, Baechle Fall 2017crwdne2935289:0
IUPUI-BAECHLE-F17S6G3
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 905
