There may be multiple reasons that the handle casing would need to be removed, whether it be to service the product, or simply replace the casing with a different colored one, following these steps will make it easy to understand what is required to perform this task.
Remove all four of the 4 mm Phillips screws on either side of the casing.
Using an opening tool, insert it along the seam where both halves of the casing meet, and slowly pry the left side of the casing from the right.
Gently pull back the right side of the casing from the center molding.
