This guide details the process of disassembling the Beboncool Gamepad for Nintendo Switch. This guide serves as the starting point for disassembly in the event that more extensive troubleshooting must be performed or as the starting procedures to replace an internal component.
Use the plastic opening tool to remove the blue plastic grips from the sides of the controller.
Use the Phillips #0 screwdriver to remove the seven 5mm screws from the back of the controller.
Gently separate the two halves of the controller.
Be sure to slide the small circuit boards out of the covers to be able to separate the two halves
Use the Phillips #0 screwdriver to remove the two 3.5mm screws holding the circuit board in place.
Lift the motherboard from the back case with the vibration motors and button boards attached.
