Beats Studio3 Wireless Battery Replacement
  1. Beats Studio3 Wireless Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Beats Studio3 Wireless Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pointed nylon spudger to remove the center circular panel on the right side of your device.
    • Be gentle while removing this piece as it is glued on with adhesive.
  2. Beats Studio3 Wireless Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Beats Studio3 Wireless Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 3.5 mm screws using a Phillips #0 screwdriver.
  3. Beats Studio3 Wireless Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Beats Studio3 Wireless Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Beats Studio3 Wireless Battery Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a pointed nylon spudger, remove the tab located on the inner part of the headband labeled "R."
    • Place the nylon spudger in between the side panels and push inward going from bottom to top to separate both sides of the panel.
    • The panel will pop open after separating.
  4. Beats Studio3 Wireless Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the nylon spudger underneath the battery, push inward and separate the battery from the inside.
    • Never use sharp tools to pry batteries. Metal spudgers can puncture an unprotected battery, potentially causing a fire.
  5. Beats Studio3 Wireless Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Beats Studio3 Wireless Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a nylon spudger to lift up the glue sticking the wires down.
    • Use a nylon spudger to lift the connector to disconnect the battery.
    the glue on the connector was a nightmare in my headset. Used a soldering iron to weaken the glue as described in a youtube video i found, but it worked out in the end :)
    seb - crwdns2934203:0crwdne2934203:0
    Me too. I watched 1 YouTube video and he just pulled the connector loose with no mention of glue. When I pulled on wires it i stripped the wires good. I the wires minus the connector buried in glue on the board.
    I watched a 2nd video and then learned about the glue.
    I'm heating up my soldering iron now. There a bundle of wires a little too close but i think i will w5rap them it aluminum foil to beside. I miss myBEATS Studio3 headphones. But now i know how to fix them. I bought them off Amazon on:
    Nov 22, 2022 so today is Aug 13, 2024
    1 years 8 months 22 days
    or 20 months 22 days
    or 90 weeks 0 days
    or 630 calendar days
    Not sure how this compares with others out there but i will compare it against my new battery.
    They claim it has more whatever... i think Amazon got me again... no reviews $1580... but it has 760mAh!!
    Here's theAmazon hype:
    [2024 New upgraded] Ultra High Capacity 760mAh Li-Polymer Replacement Battery for Beats Studio 2.0, Studio 3.0, Solo pro,Wireless Headphones with Professional Replacement Tool Kits
    Bob Elliott - crwdns2934203:0crwdne2934203:0
Lourdes Dejesus
crwdns2935283:003/16/23crwdne2935283:0
231 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 7-4, Ryckebusch Spring 2023 crwdns2935289:0UMass Dartmouth, Team 7-4, Ryckebusch Spring 2023crwdne2935289:0
UMASSD-RYCKEBUSCH-S23S7G4
Should the glue be reapplied or is it okay to simply place back on?
Jake Allen - crwdns2934203:0crwdne2934203:0
the replacement batteries usually come with a gluepad on the back.
The connector its up to you - you risk the chance of the connector coming lose and u have to reopen the headset. But ill take the chance for now, lets see how it holds up without new glue.
seb -
Tengo una duda mis audífonos la batería esta full de voltaje pero me marca un rojo y no me prenden q podría ser o que solución podría darle
luis m cruz - crwdns2934203:0crwdne2934203:0
My beats studio 3 proplem was it plink whit when i connect it with the charger, but when i press to start it it blinks full red .
My Qus is .. is the battery are dameged ..?!
Hmam - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 73
crwdns2936753:030crwdne2936753:0 317
crwdns2942667:0crwdne2942667:0 8,241
