This guide shows you how to replace the Beats Studio 2 Wireless headband, which is required when one or both earphones will not stay in the proper position. Sometimes the headband will become loose after a period of time. Replacing the headband should remedy the situation.
Slide the headband down on one side to reveal the two screws under the silver "Studio" label.
Use a T5 screwdriver to remove the two screws securing the headband pieces.
Slide the headband down on the other side to reveal the two screws beneath the "Wireless" label.
Slide the headband away from the silver "Studio" and "Wireless" silver bands.
Peel the rubber interior layer off of the headband to remove it.
Use a nylon spudger to undo the tabs connecting the foam interior of the headband to the outer shell.
Remove the foam interior part of the headphone.
