Beats Studio 2 Wireless Bluetooth Board Replacement
    1. Beats Studio 2 Wireless Bluetooth Board Replacement, Ear Cushion: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Beats Studio 2 Wireless Bluetooth Board Replacement, Ear Cushion: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Insert a spudger between the plastic part of the left headphone and the ear cushion.
      • Work the spudger around the periphery of the base of the cushion and gently pry it off the head phone.
    2. Beats Studio 2 Wireless Bluetooth Board Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Beats Studio 2 Wireless Bluetooth Board Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Beats Studio 2 Wireless Bluetooth Board Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Pull the rest of the cushion away from the adhesive with your hands.
    1. Beats Studio 2 Wireless Bluetooth Board Replacement, Speaker: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Beats Studio 2 Wireless Bluetooth Board Replacement, Speaker: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using the Phillips #00 screwdriver, remove the screws holding the speaker in place.
      • If the speaker is on the side with the charging port be sure to keep the two screws holding the charging port separate.
    2. Beats Studio 2 Wireless Bluetooth Board Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Gently separate the speaker from the headphones.
      • Don't pull or yank the speaker from the headphones. They are connected together by wires that might be damaged.
    3. Beats Studio 2 Wireless Bluetooth Board Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Beats Studio 2 Wireless Bluetooth Board Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Gently pull the wire with rubber connectors off of the speaker.
    4. Beats Studio 2 Wireless Bluetooth Board Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a soldering iron to desolder the two connections.
      • For details on how to solder and desolder, refer to the How to Solder and Desolder Connections guide.
      • A soldering iron can produce very high temperatures, and can burn skin. Use with caution.
      • Note the position of the speaker in its housing, then carefully remove the faulty speaker.
    1. Beats Studio 2 Wireless Bluetooth Board Replacement, Bluetooth Board: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Peel off the sticker underneath the speaker.
    2. Beats Studio 2 Wireless Bluetooth Board Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the center screw using a Phillips #00 screwdriver.
    3. Beats Studio 2 Wireless Bluetooth Board Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Separate the plastic case from the rubber backing by hand or with a spudger.
    4. Beats Studio 2 Wireless Bluetooth Board Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Beats Studio 2 Wireless Bluetooth Board Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a Phillips #00 to remove the four screws securing the case on top of the Bluetooth board.
    5. Beats Studio 2 Wireless Bluetooth Board Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a spudger to gently pry the left headband clip to free the earphone from the hinge.
      • This picture shows this for the right earphone, but the process should be exactly the same for the left side.
    6. Beats Studio 2 Wireless Bluetooth Board Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Slide the front case down to separate it from the back and reveal the Bluetooth board.
    7. Beats Studio 2 Wireless Bluetooth Board Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Beats Studio 2 Wireless Bluetooth Board Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the four screws from the Bluetooth board with the Phillips #00 screwdriver.
      • This will free the Bluetooth board from the back case.
    8. Beats Studio 2 Wireless Bluetooth Board Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Beats Studio 2 Wireless Bluetooth Board Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the Bluetooth board from the case.
      • Remove the translucent sticker from the back of the Bluetooth board.
    9. Beats Studio 2 Wireless Bluetooth Board Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use the pointed tip of a spudger to carefully push on each side of the connector to remove it from the socket.
    10. Beats Studio 2 Wireless Bluetooth Board Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Desolder the RYB connectors, and the connector attached to the black wire using a soldering iron.
      • For information on desoldering connections, see the How to Solder and Desolder Connections Guide.
      • The soldering iron can reach very high temperatures. Use it with caution.
Jack Wilson
crwdns2935283:003/20/23crwdne2935283:0
599 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 5-3, Ramos Spring 2023 crwdns2935289:0UMass Dartmouth, Team 5-3, Ramos Spring 2023crwdne2935289:0
UMASSD-RAMOS-S23S5G3
Hi, can you help me out with a wiring diagram to the bluetooth board, all my wires got torn loose from my old board and i do not know where to solder the new wires to which connections. If you could post a picture with which coloured wires go where , that would be most helpful, thanks.
Roger Bee_44 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 55
crwdns2942667:0crwdne2942667:0 2,934
