Beats Solo HD Speaker Replacement
  1. Beats Solo HD Speaker Replacement, Remove the foam pads from both the left and right speakers.: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Beats Solo HD Speaker Replacement, Remove the foam pads from both the left and right speakers.: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the foam pads by twisting them counterclockwise.
    • The pads should release from the grooves that are housed on the speaker inside.
  2. Beats Solo HD Speaker Replacement, Unscrew the speakers from the housing: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Beats Solo HD Speaker Replacement, Unscrew the speakers from the housing: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • There should be approximately three screws holding the right speaker. Unscrew them to gain access to the wiring of the speakers.
    • Keep the screws in a safe place. They are small and can easily be lost.
  3. Beats Solo HD Speaker Replacement, Desolder the connections to the speaker: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Beats Solo HD Speaker Replacement, Desolder the connections to the speaker: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using safety gloves, desolder the two wires of the speaker.
    • Leave the desoldered and unstripped wires for the next step.
  4. Beats Solo HD Speaker Replacement, Repeat steps in reverse to re-assemble: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Follow the instructions in reverse to put together the speaker in the housing, as well as the foam pad over the speaker.
    • Solder the new speaker to the two wires of the headphones.
    • Make sure to pack in all of the companents back into the housing when finished with this step.
  5. Beats Solo HD Speaker Replacement, Repeat steps for left speaker: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If you need to repair the left speaker, there may be an additional step you need to take to replace the speakers. This takes the audio jack into account.
crwdns2935229:08crwdne2935229:0
redacted
crwdns2935283:010/11/14crwdne2935283:0
544 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 1-1, Donnelly Fall 2014 crwdns2935289:0USF Tampa, Team 1-1, Donnelly Fall 2014crwdne2935289:0
USFT-DONNELLY-F14S1G1
Hello. I also have 1 damaged Monster Beats Solo. It was bought in 2013. The right speaker does not working properly - it sounds softer (opposite of lourder) than the left speaker and whenever I move, I can feel the sound of something loose inside the right ear cup/speaker. I already found some sellers selling the replacement speakers on ebay. Before buying the replacement parts, I decided to open the ear cup myself to check whether it is easy to open or not. However, so far I am unable to open it. I avoind using too much force because it is afraid that I might break the headphone.
SHAMSUL FAISAL MOHD HUSSEIN - crwdns2934203:0crwdne2934203:0
According to some websites, the twist counter clockwise removal of the headphone pad is indicative of a fake beats solo HD, the genuine ones have fixed pads apparently. I can't guarantee this, but I do have a set of solo HDs with a faulty speaker and I can't easily remove the pad either
Simon16a - crwdns2934203:0crwdne2934203:0
you forgot to mention polarity which matters if you mess that up ull get a lack of bass and phasing issues positive and negative should be clearly marked and a link to a proper replacement you should give proper instructions on how to check for proper polarity with a volt meter for those who dont know.
bob king - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 19
crwdns2936753:030crwdne2936753:0 77
crwdns2942667:0crwdne2942667:0 107,396
